1989 Jaguar XJS No Start No Injector Power
60 MILES • 5.3L • AUTOMATIC
YVONJAG1989
Hello Here is my issue Engine will not start turns ok tac moving on start have fire have 40 lbs pressure on fuel rails . Before i need to tell you that i had the car towed at my place after it stalled when taking a ride. Had no fire on plugs.. Pick up coil in distributor was replaced.Now allis correct good spark but will not start . When spraying gas in intakes car will run. Where is the problenm never had such issues on my Jaguars??? Thanks for helping. Is there a fuse on the injectors wiring??
Nov 5, 2026 at 11:47 AM
  • 55,845 POSTS
Yep, the best thing to do is see if the fuel injectors are getting a signal and power, here is a great guide that can help you with the testing.
https://2carpros.com/articles/how-to-test-a-fuel-injector/
Please let me know what you find.
This video may help as well.
https://www.youtube.com/watch?v=lXLJbuAZ4CE
Nov 6, 2026 at 1:07 PM
YVONJAG1989
Hello thanks for the fast reply. Have tested all components.on my xjs v12 good spark on plugs , good fuel pressure . no start Spraying fuel in intake .engine run a few second.. no other results. no injector power at all.
Nov 7, 2026 at 6:47 AM
  • 55,845 POSTS
To be clear, the fuel injectors do NOT have power when the key is on correct? So this can be a few different problems, we need to see where you loose power, the ECM is run by the EFI switching relay and the MAIN relay. Here is the fuel injector wiring diagrams and a guide to help you test for power to see where you lose it.
https://2carpros.com/articles/how-to-use-a-test-light-circuit-tester/
Nov 7, 2026 at 11:27 AM
Suggested Repair
Confirm the injectors have no power with the key on, then trace the injector and ECM power circuit with a test light. Check the EFI switching relay and main relay to find where power is lost.
Conversation Summary
A 1989 Jaguar XJS V12 cranks with a moving tach, good spark, and about 40 psi fuel pressure but will not start. It runs briefly only when fuel is sprayed into the intakes. After the distributor pickup coil was replaced, the owner found no injector power. The expert advised testing injector power and signal and tracing the loss through the EFI switching relay and main relay.
