Engine turns over will not start?
150,000 MILES • 4.9L • V8 • 2WD • AUTOMATIC
CARLEEN LEE ONNEN
car sat for a few years we drove it home and put gas in it. now it won't start. We cleaned the lines and filters it turns over but won't start. The thing acts like it's starving for gas. but we can find the block. and the idle control makes a funny noise. IAC Idle control?
Nov 30, 2023 at 8:34 AM
  • 110,248 POSTS
In most cases, a crank no-start condition is caused by either a fuel-related issue or ignition-related issue.
Here is what I need you to do. See if the engine will start if you use starting fluid. If it does and then stalls, we will know it is a fuel-related issue. If there is no change, I need you to check if there is spark to the spark plugs.
Here is a link that explains how to check for spark:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Additionally, here is a link that explains how to retrieve diagnostic trouble codes. You don't need a scanner for this vehicle. All that is needed is either a short jumper wire or a paper clip.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Try this and let me know what you find.
Nov 30, 2023 at 11:51 AM
CARLEEN LEE ONNEN
Check the spark plugs and they were pretty gummed up he's cleaning those.
Dec 2, 2023 at 2:53 AM
CARLEEN LEE ONNEN
And it is getting spark.
Dec 2, 2023 at 2:54 AM
  • 110,248 POSTS
Were you able to check if it starts using starting fluid? If it has spark to the plugs, it is likely a fuel-related issue.
Dec 2, 2023 at 11:44 AM
LL BAILEY
I need a diagram of the fuse box and relays.
Dec 6, 2024 at 1:06 AM
  • 55,594 POSTS
please post your new question here, you must be logged in.
Cheers, Ken
Dec 6, 2024 at 1:53 AM
