This car has all ways started. I put a new battery in it an it will not start, it will turn over. If I put gas in the carb it will start up, but die once the gas runs out? Also the trunk will not tighten down. I cked all the fuses in the car an under the hood, is it possible there is a fuse for the gas pump somewere inline with the gas pump? That it. Hoping there is so I dont have to re place the gas pump. Again the car allways started thank, bruce
SPONSORED LINKS
Monday, May 10th, 2010 AT 7:32 PM
