TURNS OVER BUT WILL NOT START
TINA GUTIERREZ
  • 1987 MAZDA B2200
  • 2.2L
  • 4 CYL
  • 216,286 MILES
My truck cranks over but it will not start. While I was driving it stalled I waited a while and then I was able to start it and drive home. I replaced the fuel filter, it started up and drove for about half a mile and then it did the same thing. I checked the choke and cleaned with carburetor cleaner, still no start so I replaced the fuel pump which is electric and it still will not start. When I was checking the coil I removed the plug from the coil and plugged it back in and it started. Once again I drove it for about a half a mile then it started running rough I gave it more gas and it ran fine but then it stalled on. Now it will not start.
I have replaced the coil, spark plugs, cap, rotor, fuel filter and fuel pump. Help!
Wednesday, July 13th, 2016 AT 11:01 PM
HMAC300
  • 48,601 POSTS
Check resistance of plug wire may be bad, 5000 ohms per foot then check for spark and blown fuses. Finally check relays.
Thursday, July 14th, 2016 AT 6:29 AM
TINA GUTIERREZ
Thanks, I check the plugs I had no blown fuses, but which relays do I check?
Thursday, July 14th, 2016 AT 2:59 PM
HMAC300
  • 48,601 POSTS
If yo have them the main and pgm mostly. Also try resetting security system if no manual look online.
Thursday, July 14th, 2016 AT 4:53 PM
