1987 Mazda B2200 No power can't start.I fixed it today
HONORE
  • 1987 MAZDA B2200
  • 4 CYL
  • MANUAL
  • 110,000 MILES
I fixed the problem by replacing the 80a main switch rellay or fuse in the ingine compartment.
I left my lights on and the battery drained so I charged it and now I have head lights rear lights emergency lights and dome light and door buzzer. I don't have radio heater fan no lights on dash and no signal lights. Can't start don't even hear the starter click. Can that be a fuse and which one. I checked the fuses and could not see anything wrong. Can it be a fuse in the main box under the hood?
Monday, July 7th, 2008 AT 11:44 PM
BMRFIXIT
  • 19,053 POSTS
Main fuse block is located in engine compartment and contains high AMPS fuses protect multiple circuits.
Also you have a fuse box located near driver's left knee and accessible through a removable cover, contains fuses for individual circuits.
You can use a test light and volts meter to check the fuses
if all fuses check OK I would suspect a wire and or ignition switch
good luck
Wednesday, July 9th, 2008 AT 5:49 AM
