My truck turns over but will not start
ACOOLTONYT
  • 1995 FORD RANGER
  • 4 CYL
  • 230,567 MILES
My truck turns over but will not start. I replaced fuel pump, crank sensor, fuel filter, fuel pump relay and even throttle body, but will not start. Fuel rail is getting fuel but will not start. I put starting fluid in it and it runs for bout forty seconds. Any suggestions?
Tuesday, November 14th, 2017 AT 2:36 PM
  • 110,055 POSTS
Check to make sure the fuel injectors are getting power. If it runs on starting fluid, it's a fuel related issue. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Tuesday, November 14th, 2017 AT 7:50 PM
