Truck not starting
300,000 MILES • V8 • 4WD • MANUAL
RICH PEARSON
Will not start after it has been in the rain. Thoughts?
Jun 17, 2018 at 10:48 AM
  • 110,248 POSTS
The first thing I would recommend checking is the distributor cap and the coil. Here is a simple way to check if there is an issue. When it is dark outside, start the truck, open the hood, and mist water on all ignition components to see if anything is arcing or if the engine shuts down.
Try that and let me know what happens.
Jun 18, 2018 at 1:15 PM
