1998 Dodge Ram 1500 4WD 5.2L Automatic will not start but the ignition does turn over. New battery in place also. It does not fire at all but I do have spark. I replaced the ASD and that did not help. I was wondering if it is a fuel pump/clogged fuel line issue and how I would go about checking that. Also I need a special tool to uncouple the fuel line where it joins the fuel rail. I have been unable to locate that tool.
The truck was running fine prior to this problem. I tried to start it, it fired and I released the ignition but then it promptly died. It only ran for probably 2 seconds.
Thanks for your help. If I can get this figured out I will send you some more dinero!!!
Mar 22, 2010 at 6:40 AM
