Transmission control module?
HMAC300
  • 48,601 POSTS
I don't think the tcm has a fuse if it does it would be probably marked ecm 1 or 2 and it's underhood for those.
Monday, September 7th, 2020 AT 1:13 PM (Merged)
HMAC300
  • 48,601 POSTS
Try it your trans may not work or it may. But will still need programming.
KRISTINAWHITE09
  • 44 POSTS
I've checked just about every fuse in the engine. I'm going to start with the ones in the passenger side panel first then recheck the ones under the hood. I'm hoping it's maybe the BCM relearning the programming from yesterday. I've read (and the dealer finally told me) that it can take at least a day for the modules to relearn the programming when you have it done. Some people said it could take a week or more. Thank you!
KRISTINAWHITE09
  • 44 POSTS
I actually found a tow for free, so I think I'll just have it towed over there. Thank you very much for all your help!
