Hard shifting out of first gear
214,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
JENNIFERGSELL1
The truck is shifting hard out of first gear, saying overdrive is off.
May 24, 2018 at 11:32 AM
HARRY P
  • 2,292 POSTS
When the overdrive light comes on by itself in a Ford (or Mercury) vehicle, it is telling you that the transmission computer has detected a problem and set a trouble code. Take it to a transmission shop and have the codes pulled. Come back here with the code numbers and we will be able to make a more educated response as to what is wrong. It could be something really simple.
May 24, 2018 at 9:53 PM
