1986 Toyota Pickup Stalls When Warm
SLIMACIDE
86 toyota 2WD 113000 mi.
Starts fine when cold but stalls and will not idle when warm. Also left me beside the road last time I drove it. Would start but would stall out like it wasn't getting enough gas when I tried to drive away.
I only drive this truck 3, 4 times a year. it stays at a camp. But it is started regularly.
Thanks.
May 1, 2006 at 2:28 AM
LOSONE
  • 1,616 POSTS
Sounds like you have to do some basic tune up stuff after all it sits and deosn't go any where. Check all the common items like fuel filter. plugs, air cleaner and most important have fresh good gas in the tank. Gas does spoil after about a year--don't let it go too long or you will have major problems. Good Luck
May 1, 2006 at 4:01 AM
Suggested Repair
Perform a basic tune-up: check the fuel filter, spark plugs, and air cleaner, and use fresh gasoline because old fuel can spoil.
Conversation Summary
The owner of a 1986 Toyota Pickup says it starts fine when cold but stalls and will not idle once warm, and once stalled as if it was not getting enough fuel. The truck is driven only a few times a year. The expert recommends a basic tune-up, checking the fuel filter, plugs, and air cleaner, and using fresh gas.
