1988 Toyota Pickup Dies at Idle
SQLHAWKN
I just bought a 1988 Toyota truck, 4x4, AT, V-6 with 255,000. It has been parked for almost two years.
Nothing has been done yet. (new gas, plugs, etc.)
Where Do I Start?
Could the gas be bad, plugs, fuel pump/filter???
The truck will crank but only if I give it gas. When I let off of the gas it dies.
There is also a loud clicking noise coming from the engine. Increase in RPM = faster and louder noise but as the RPM's decrease the noise will go away until back around idle speed.
Any help will be SUPER HELPFULL
Apr 14, 2006 at 3:49 PM
LOSONE
  • 1,616 POSTS
Drain all engine liquids, change all filters. Drain the gas and try and flush the tank with clean fuel. The bad gas is your problem as well as probably a bad fuel pump from sitting in bad gas. Good luck let me know.
Apr 18, 2006 at 8:52 AM
Suggested Repair
Drain and replace the engine fluids, change the filters, drain the old fuel, and flush the tank with clean fuel. Suspect stale gas and a fuel pump damaged by sitting in bad fuel.
Conversation Summary
The owner of a 1988 Toyota Pickup that sat nearly two years says it only runs when the throttle is held and dies at idle, with a clicking noise that changes with engine speed. The expert advises draining fluids, changing filters, flushing the fuel tank, and checking for a fuel pump damaged by stale gas.
