1987 Toyota Pickup Black Smoke Stalls
check the carburetor..
Rie
Good Luck!
You need to adjust the choke and fast idle cam
Further check out the Thermostatic Air Cleaner system Hot and Cold position.
22R Engine, easily converted to 22RE set up
[quote="rasmataz"]Its soung like a choke plate is binding or the Vacuum break is not pulling it to the initial point creating the loading of fuel.
22R Engine, easily converted to 22RE set up[/quote]
Suggested Repair
The engine is running too rich. Check the carburetor, including the vacuum-actuated neoprene diaphragm, which can leak fuel into the vacuum system if perforated. Also check for a binding choke plate or a vacuum break that is not opening the choke, adjust the choke and fast-idle cam, and verify the thermostatic air cleaner moves between hot and cold positions.
Conversation Summary
A 1987 Toyota Pickup with a 22R engine starts, sputters, blows black smoke, and dies; it also misses on cylinder 2 and the fuel gauge does not work. A recent tune-up and distributor cap replacement did not fix it. Replies say it is running rich and recommend checking the carburetor, a perforated vacuum diaphragm, choke and vacuum-break adjustment, the fast-idle cam, and the thermostatic air cleaner.
