1993 Toyota Pickup Water in Oil
CASSYP
I have a '93 Toyota pickup 4cyl with 145k miles on it. Recently it overheated, there wasn't very much smoke so I didn't think it was my head gasket. My radiator was cracked so I replaced it with a brand new one. I took it for a test drive, it ran fine until it got warm, it started to shake so I pulled over. I checked the oil and there is water in it. Do i have a blown head gasket? Everyone keeps telling me I will need a new engine if that is the problem.. Can you help? Thanks!
Aug 10, 2007 at 9:20 AM
  • 75,988 POSTS
[quote:94b7f14653="Cassyp"]I have a '93 Toyota pickup 4cyl with 145k miles on it. Recently it overheated, there wasn't very much smoke so I didn't think it was my head gasket. My radiator was cracked so I replaced it with a brand new one. I took it for a test drive, it ran fine until it got warm, it started to shake so I pulled over. I checked the oil and there is water in it. Do i have a blown head gasket? Everyone keeps telling me I will need a new engine if that is the problem.. Can you help? Thanks![/quote:94b7f14653]
For me I would say Yes, you do have a blown gasket to confirm get a block/pressure/leakdown test and you do not need a new engine and again it depends what is damaged when it overheated.
Aug 10, 2007 at 12:15 PM
Suggested Repair
Confirm a suspected blown head gasket with a block, pressure, or leakdown test. A new engine is not automatically required; inspect for damage caused by overheating before deciding on repairs.
Conversation Summary
The owner of a 1993 Toyota Pickup reported overheating, a cracked radiator that was replaced, shaking once warm, and water in the oil. The expert said this indicates a blown head gasket and recommended a block, pressure, or leakdown test. A new engine is not necessarily required and depends on what was damaged by overheating.
