I have a 1987 Toyota pickup 4cyl 22r carburated, I just replaced the alternator on it because the charge light on the dash had come on and it was causeing my motor to rev really high, I removed the positive cabel on the battery and changed it out, when I placed the battery cable back on, my oil and brake light in the dash had come on, when I turned the key and started my truck the lights go off, when I go to turn the truck off the oil and brake light come back on, so I had to remove the fuse 40amp under the hood so that the lights would go off without draining my battery, I have never had this problem with my truck!
Jan 30, 2007 at 10:27 AM
