driver side brake light stopped working
GHOZER3
I tried replacing the bulb and I even replaced the whole light fixture but the driver side brake light still does not work. Any ideas? The other side works fine....and on the driver side reverse light and turning signal light both work...it is just the brake light on that one side is not working.
Oct 25, 2013 at 1:33 PM
CARADIODOC
  • 34,414 POSTS
Check for voltage to that brake light while a helper presses the brake pedal. With no wiring diagram to look at, just use a test light to probe each terminal of that bulb's socket. If no voltage is found there, suspect the turn signal switch. We know the brake light switch is working because the right brake light works. If the left rear turn signal bulb is the same one as for the brake light, and the left turn signal works, that proves the bulb and wiring are okay.
Oct 25, 2013 at 4:27 PM
