1987 Toyota Pickup Water From Tailpipe
BUZIEMOMMA3
I have an 87 toyota pick up 22R 5 speed. My problem is husband put a rebuilt engine in it. Now water comes out of the tail pipe. We have changed the intake manifold 3 times, the head, and all gaskets twice. Any idea as to what could be causing this to happen? :(
May 28, 2007 at 7:54 AM
  • 75,988 POSTS
Maybe a crack cylinder block
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
May 28, 2007 at 8:58 AM
Suggested Repair
Have the cylinder block inspected and pressure tested for a crack that lets combustion leak into the cooling system, or use a gas analyzer to check for hydrocarbons at the radiator fill neck. Do not pressure-test if the head gasket is leaking; repair the head gasket first so coolant cannot enter the cylinders and cause hydrolock or rod damage.
Conversation Summary
The owner of a 1987 Toyota Pickup with a 22R reports water coming from the tailpipe after a rebuilt engine was installed. Replacing the intake manifold, head, and gaskets did not stop it. The expert suggests a possible cracked block and recommends block testing or a hydrocarbon sniff test at the radiator, with a caution not to pressure-test until any head-gasket leak is repaired.
