1988 Toyota Pickup Idle Stays High
LYLO
I have a 1988 Toyota Pickup, 2.4L 4cyl. When the engine is accelerated the RPM's go up but when you let off the gas the RPM's don't come down. I troubleshot it through a repair manual and decided it was the Dashpot malfunctioning. I decided this because when i pulled the VT valve off the Dashpot i was able to get the engine to kick down to normal idle after a quick punch of the gas (before nothing would get it down). I adjusted the Dashpot to the point that it did not connect to the throttle, but the engine will not kick down on its own (with out quick rev). Now I'm at a loss. The engine idles good when it is idling.
Thanks for any help
Lyle
Sep 7, 2007 at 7:06 AM
  • 75,988 POSTS
[quote:282243e9dc="lylo"]I have a 1988 Toyota Pickup, 2.4L 4cyl. When the engine is accelerated the RPM's go up but when you let off the gas the RPM's don't come down. I troubleshot it through a repair manual and decided it was the Dashpot malfunctioning. I decided this because when i pulled the VT valve off the Dashpot i was able to get the engine to kick down to normal idle after a quick punch of the gas (before nothing would get it down). I adjusted the Dashpot to the point that it did not connect to the throttle, but the engine will not kick down on its own (with out quick rev). Now I'm at a loss. The engine idles good when it is idling.
Thanks for any help
Lyle[/quote:282243e9dc]
Try readjusting the choke initial opening and fast idle cam.
Sep 7, 2007 at 8:44 AM
Suggested Repair
Readjust the choke initial opening and the fast idle cam so the engine can return to normal idle after the throttle is released.
Conversation Summary
The owner of a 1988 Toyota Pickup with a 2.4L four-cylinder reports that engine speed rises when accelerated but does not fall back to idle when the throttle is released. Idle is otherwise normal. After checking a repair manual, the owner suspected a dashpot problem because disconnecting the VT valve from the dashpot allowed a quick rev to bring the engine down, but adjusting the dashpot so it no longer contacted the throttle did not restore a normal return to idle. The expert advised readjusting the choke initial opening and fast idle cam.
