1994 Toyota Pickup erratic idle
125,074 MILES • 4 CYL • 2WD • MANUAL
VINNY.THE.NOSE
Runs good at all speeds, idle is erratic when brake is applied. Idle is erratic with slight fuel preasure, then smoothd out at higher rpm.
Jan 19, 2009 at 4:39 AM
  • 75,988 POSTS
Runs good at all speeds, idle is erratic when brake is applied. Check vacuum hose to the brake booster if its leaking and also the booster itself-could also be the idle air control valve and throttle position sensor
Jan 20, 2009 at 9:10 AM
