Friday, August 24th, 2007 AT 11:11 AM
I just bought this pickup its a 86 pickup with the 22r motor with 228,000 miles. It starts and runs fine after it has sat for awhile, if you do any highway driving further than five miles and then it won't start. I took the air cleaner off and there was oil standing in the housing, and the filter was drenched in oil. I replaced the PCV valve, but there is another hole coming from the valve cover that has a hose going from it to the air cleaner. This is where its coming from. I took of the hose and started the truck, and there was alot of pressure coming from the valve cover. It was like steam with oil mixed in. ANy help would be appreciated.
