Intake manifold
13,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
JEFFK.
If the intake manifold failed, would I experience sudden loss of power, intern leading to loss of oil pressure?
Feb 27, 2016 at 7:09 AM
HMAC300
  • 48,601 POSTS
not really, intakes do not normally fail but if they did more than likely your car would quit running. if you have no oil pressure then check your oil level first. then have things like pump checked or if driven by a chain maybe chain has broken. Bearing could have failed as well but normally you'll hear a knock if that happens.
Feb 27, 2016 at 7:14 AM
JEFFK.
Thanks, also if intake did fail could water have leaked into the oil?
Feb 27, 2016 at 7:21 AM
WRENCHTECH
  • 20,760 POSTS
This is a follow up question from here https://www.2carpros.com/questions/water-in-oil-loss-of-pressure
Feb 27, 2016 at 7:47 AM
CATAFINA
  • 167 POSTS
Could be-check the oil if its milky
Feb 27, 2016 at 7:48 AM
  • 31,937 POSTS
What actually happened to the manifold what was the failure?
Feb 29, 2016 at 4:03 PM
MAXIMILIAM
  • 436 POSTS
Could you please tell me how thermo switches disconnect?
Jeffk.
Mar 7, 2016 at 2:46 PM
