My engine is hard starting?
V VINCE GOHEEN
  • 1992 TOYOTA PICKUP
  • 3.0L
  • V6
  • 110 MILES
We use to be able to get in start it up and drive away, then I noticed it needed to warm up some then it would drive or the pedal might go to the floor and shut off the engine. Like now one day of draining the battery trying to start it. I tried starting fluid, nothing, recharge. I did the full throttle cranked it over and it would run at 450 rpm but at full pedal or it would shut off. It is a motorhome built of a 1992 Toyota truck one ton frame. Please, not head gaskets, replaced plugs and it does have spark and I do not believe you sloped a timing belt 45 psi fuel after the filter, sprays at banjo fitting. Can it be a fuel pressure regulator? Filter was clean so fuel lines should be fine I would assume. Are the injectors prone to sensor damage or suggestions. Thank you
Monday, November 16th, 2020 AT 8:32 AM (Merged)
GAB56
  • 6 POSTS
But when it starts up, it is perfectly fine. It will fire right up and stay running. I just asked my dad about the fuel pump though and said that we have not looked at that yet
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,721 POSTS
I would start by running the codes to see what comes up so we can get started int he right direction.
https://www.2carpros.com/articles/toyota-trouble-code-definitions-and-code-gathering-method-1990-1995
and
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Please let us know what you find.
Cheers, Ken
KHLOW2008
  • 41,814 POSTS
A fuel pump can fail intermittently and fuel pressure can drop in lines after engine is stopped. Thie would require the fuel pressure to build up.
Fuel pressure has to be tested after vehicle is left idle for extended periods, meaning you need to install the pressure gauge, start engine. Stop it and leave it for exended periods to check. Upon initial ignition on, check if the fuel pump is priming.
V VINCE GOHEEN
No codes given. As I said it will start at full throttle, and will get up to temp running on all cylinders, but @ low rpm, if put in gear ( auto transmission) I bet it would die, I did feather it half throttle to full throttle and it once came up to full throttle, I backed off not to over rev the engine it went back to as mentioned low rpm. But no codes. Filter was changed I can see thru the old filter a screen mess, clean after I blew it out by mouth. My only thought not knowing much. Regulator, all the injectors. As said sprays at all banjo fittings, New plugs, old looked good, has to be lack of fuel. Right? Any known sensors I can jump or suggested go bad? Thanks
GAB56
  • 6 POSTS
So what your telling me, is that I should install this gauge and take a look at the fuel pump/ pressure? How much does this usually run for just parts, considering I could do it myself.
V VINCE GOHEEN
Does the air flow meter have a test? It did back fire and blew off that intake tube to intake to it?Mass air flow or the one at butterfly? Culprits?
KHLOW2008
  • 41,814 POSTS
You need to check the parts prices locally as they can vary according to location.
Yes, you definitely need to test the fuel prtessure to know if it is within range.
KEN L
  • 48,721 POSTS
Yep, that's where I was going to go next, it is difficult to check the MAF because the values can be off enough to create a problem but if you don't have a good one to test against you will never know.
See if the air door moves freely inside of the sensor.
Cheers, Ken
GAB56
  • 6 POSTS
Awesome. Well ill let you know what happens after I do that. Because just this morning, it took over 20 cranks to get it going. Then after my class, it only took one turn. Sound like the fuel pressure?
KHLOW2008
  • 41,814 POSTS
With 20 cranks, if it is due to fuelpressure, it most probbly means the fuel pump was not working for that period.
BUBBA06
  • 1990 TOYOTA PICKUP
  • 4.3L
  • V6
  • 4WD
  • 218,000 MILES
Recently bought the vehicle had this issue before I purchased. Has had many repairs prior to and since I purchased it as follows. Timing set, water pump, complete tune up ie, plug wires cap rotor and coil pack. Due to stripped fuel line fittings at both inlet &outlet of fuel filter it had not been serviced for over 2 yrs. However I recently changed it and it was definitely plugged it made a noticeable difference but still starts hard when cool. After running 10min. Starts fine as long as it is warmed up. Also has check engine light on intermittently. It will be off for several days and randomly come on and back off. Eng. Light will also come on if the pickup is let run for extended periods. I have not yet checked O2 sensor. Please help
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure with a gauge autoparts rent it. If it's injected should be 38-44 psi with vacuum disconnected and 33-37 with. If carb then it should be 5 psi both shold flow about 1/2 pint in 30 seconds
