2005 Toyota Tundra Weak Radio After Surge
RYEFKO
2005 Tundra 4.7 Crew Cab, 17k miles. If my alternator/voltage regulator was affected by a surge/spike and it wasn't putting out enough power, would it cause my radio to underperform, ie: doesn't have the powerful sound it once did. The alternator's readout was LOWER when revving at 2000rpm, than ay idling. Any advice would be appreciated. (this stated with a power surge through the cigarette lighter from a device I plugged in).
Aug 18, 2007 at 11:32 AM
  • 75,988 POSTS
[quote:24ed0c35f2="ryefko"]2005 Tundra 4.7 Crew Cab, 17k miles. If my alternator/voltage regulator was affected by a surge/spike and it wasn't putting out enough power, would it cause my radio to underperform, ie: doesn't have the powerful sound it once did. The alternator's readout was LOWER when revving at 2000rpm, than ay idling. Any advice would be appreciated. (this stated with a power surge through the cigarette lighter from a device I plugged in).[/quote:24ed0c35f2]
Before you start check the electrical system for a short circuit
Get the battery and alternator recheck by loading it. You probably fried something thru the ignition switch that the alternator is being affected.
The Cigarette lighter is it still working?
Aug 18, 2007 at 11:48 AM
Suggested Repair
Check the electrical system for a short circuit, then have the battery and alternator load-tested. A surge through the cigarette lighter may have damaged ignition-switch circuitry that affects charging. Also confirm whether the cigarette lighter still works.
Conversation Summary
The owner of a 2005 Toyota Tundra asks whether a surge through the cigarette lighter damaged the alternator or voltage regulator and caused weaker radio sound. Voltage was lower at 2000 rpm than at idle. The expert recommends checking for a short, load-testing the battery and alternator, and verifying that the lighter still works, noting possible ignition-switch-related damage.
