1993 Toyota Pickup another charging issue 4 alternators
1993 TOYOTA PICKUP
LEEFTIDE
Electrical problem
1993 Toyota Pickup 4 cyl Four Wheel Drive Manual 240k miles
My truck ran fine for years, then bam 1 battery and 3 alternators later. I have a new battery and this alt should be good. With the truck running voltage is only 12.9 and falling. The grounds seem to be good "0" resist from the alt to the block, ".03" bounces lower depends were I have the leads hooked to. I checked from the (-) terminal to the alt case reads .02 and from (+) terminal to (+) lead at the alt .06 . I did disonnect the positive cable w/ truck running, it goes dead. I have since learned this is not a good idea it may cause a spike with the alt and could fry my ECM not good. Shold I check the "L" pin on the back for voltage (running or not runnin??) the80amp fuse for the alt blew once but not again. any help would be great
Jan 18, 2008 at 1:22 PM
If it has little hole on the back of the alty-stick a metal object in and ground the tab-this will make the alternator throw everything its got.if not the alternator is bad. if so replace the voltage regulator.
This is what you called full fielding the alty. operating w/o the regulator
Jan 18, 2008 at 1:40 PM
