1992 Toyota Pickup Alternator
RATATE
I have a 1992 toyota pick up.The engine is an 22RE 4 cylinder, Two wheel Drive. Can I replace the brushes on the alternator and when I do replace the brushes how much of the brushes should be exposed to the shaft of the alternator. If you can, could you draw out an diagram to show me or let me know of a site that I could get this info.
Feb 4, 2007 at 11:13 PM
LOSONE
  • 1,616 POSTS
Don't come close to trying to repair a Toyota alternator. The problems could be the diodes and or brushes. Take it off and buy a rebuilt one. This is good advice from an old Totoyta mechanic.
Good Luck
Losone
Feb 5, 2007 at 3:44 AM
LOSTINMARS
  • 222 POSTS
i agree, for what quality remans cost, its not worth the hassle
Feb 6, 2007 at 1:27 PM
  • 75,988 POSTS
I love conservative people, its the only way too learn BTDT many moons ago-now a days am spoiled I fix with replacement after a thorough diagnosis with high tech tools and testing equipment. Oh! lord my back is killing me an old gizzard with brains.
Something tells me all you need is a little coaching. The brush is spring loaded just set it on it'll adjust itself.
Are you sure its the brush-better do full-fielding the alty to confirm what the regulator is doing.
Find the hole for the field terminal on the Alty then ground it-now observe the voltmeter if it goes in between 14-15 volts-if it does than you're fine and dandy-no need for brush or reman. stuff. keep on truckin...
On your side if all else fail-comeback and I'll give you block to block,step by step how to nail your problem.
I've been around when Toyota was Toyopet.
Feb 6, 2007 at 6:06 PM
Suggested Repair
Do not try to rebuild the Toyota alternator. Remove it and install a quality remanufactured unit, since diodes or brushes may be faulty. If diagnosing first, ground the field terminal and confirm charging voltage rises to about 14-15 volts; brushes are spring-loaded and self-adjust if replaced.
Conversation Summary
The owner of a 1992 Toyota Pickup with a 22RE asked whether the alternator brushes can be replaced and how far they should extend toward the shaft. Two experts advised against repairing a Toyota alternator and recommended a rebuilt unit because the diodes or brushes may be bad. A third expert said the spring-loaded brushes self-adjust and suggested grounding the field terminal to see if voltage rises to 14-15 volts before replacing parts.
