1990 Toyota Pickup alternator?
1990 TOYOTA PICKUP
200,000 MILES • 6 CYL • 4WD • MANUAL
STEVE REYNOLDS
my trucks battery and brake light come on and go off and now they stay onall the time. I had my alternator tested and it tested good, now the voltage regulator is built into the alternator is it possible that is the voltage regulator is no good.I have also cleaned alot of connections
Nov 30, 2008 at 5:57 AM
  • 31,937 POSTS
Hi there,
If the battery light is coming on, this is an indication that the alternator is not charging, the regulator is just part of this system, i would have the alternator tested when the light comes on, as it may be an intermittent problem at this stage,
mark (mhpautos)
Nov 30, 2008 at 7:59 AM
