1971 Toyota Pickup Clutch Leak
DANDCGROUNDS
I have a 1971 Toyota 1.9L 4speed manual and i've had some leak coming from the clutch at the firewall, and my fluid is empty (i'm assuming its a hydralic clutch) Well my question is can this problem be fixed or will I need to replace the master cylinder or buy the rebuild kit either way if you could give me any tips on repair'ing or installing I would appreciate it. Thanks again
Aug 11, 2007 at 8:52 PM
  • 75,988 POSTS
[quote:5ccffeb18f="dandcgrounds"]I have a 1971 Toyota 1.9L 4speed manual and i've had some leak coming from the clutch at the firewall, and my fluid is empty (i'm assuming its a hydralic clutch) Well my question is can this problem be fixed or will I need to replace the master cylinder or buy the rebuild kit either way if you could give me any tips on repair'ing or installing I would appreciate it. Thanks again[/quote:5ccffeb18f]
Get a new clutch master cylinder bench bleed it-install the line to it now go bleed the slave/servo with a helper-no helper use the Mityvac
Aug 12, 2007 at 12:08 AM
Suggested Repair
Replace the clutch master cylinder with a new unit. Bench bleed it, connect the line, then bleed the slave cylinder with a helper or a Mityvac if working alone.
Conversation Summary
The owner of a 1971 Toyota Pickup with a 1.9L four-speed manual reported a clutch fluid leak at the firewall and an empty reservoir, and asked whether the hydraulic clutch could be repaired or needed a new master cylinder or rebuild kit. The expert recommended installing a new clutch master cylinder, bench bleeding it, connecting the line, and then bleeding the slave cylinder with a helper or a Mityvac.
