Radiator Seam Leak - top, 1989 Toyota Pick-Up
1989 TOYOTA
JIMKUNKLE
Hello, have an 89 Toyota Pick-Up, he's in great shape, just had a power flush-n-fill done on my radiator to prepare for winter, live in PA. The provider that I've been using for years told me that I have a slight seam leak at the top side (near battery side), advised me option to replace the radiator or might have to watch coolant level, make sure levels are full, bought Prestone 50/50 & check every few days have seen signs inside under the hood of small leaking, but tonight after getting home from work found few hours later approximately radiator fluid on my blacktop, about 4-6oz worth, what do you recommend that I do?
Thanks
Nov 16, 2006 at 11:06 AM
BACKYARDMECHANIC
  • 337 POSTS
If the leak is not obvious have the shop do a pressure test to determine where the leak is . If it is obvious than replace the raditor. Something to think about, is it the original radiator?
Good luck Backyardmechanic
Nov 19, 2006 at 8:01 AM
