2003 Toyota Pickup Clutch Ticking
SHANEGUN
I own a Toyota mini-truck 4x4 - 2003 , 3.0 turbo diesel , non-intercooled, 55000 miles
I have been hearing a ticking noise when the clutch is released full while in gear or in neutral. Is this the sign of clutch failure? If so , do i need to replace the clutch disc, flywheel , pressure plate and throw-out/release bearing or can i replace individual components?
Any help would be great , Thanks
May 21, 2007 at 12:02 AM
  • 75,988 POSTS
[quote:aac040b38c="shaneGun"]I own a Toyota mini-truck 4x4 - 2003 , 3.0 turbo diesel , non-intercooled, 55000 miles
Any help would be great , Thanks[/quote:aac040b38c]
Ticking noise while clutch is fully release-something in there is on its way out-you need a clutch assy kit.
You sure its coming from the clutch assy area?
May 21, 2007 at 11:15 PM
SHANEGUN
Yes . the noise sounds like its comming from inside the bellhousing area. Ive checked it while in neutral. but is even more prevalent when cruising along slowly in 3rd or 4th. i`m sure its there for the other gears but i cant hear it clearly because of the engine and road noise on 1st and 2nd and 5th
May 21, 2007 at 11:21 PM
Suggested Repair
Confirm the ticking is coming from the bellhousing/clutch area with the clutch fully released. If so, replace the clutch as an assembly kit rather than individual parts, since something in the clutch assembly is failing.
Conversation Summary
The owner of a 2003 Toyota mini-truck 4x4 with a 3.0 turbo diesel reports a ticking noise when the clutch is fully released, in gear or neutral, sounding like it comes from the bellhousing and more noticeable while cruising in 3rd or 4th. The expert said a ticking noise with the clutch fully released means something in the clutch assembly is failing and recommended a clutch assembly kit, while asking whether the noise is definitely from that area. The owner confirmed it is from inside the bellhousing.
