1997 Toyota Tacoma Misfire Under Load
MAGICMAN53
toyota tacoma extended cab, 3.4l v-5 engine, 158,000 miles on it. Initially my check engine light came on and it said #1 cylinder misfire so I replaced the 3 ignition wires, changed the plugs. it seem to run better but it bogs down when I mash down on the accelerator. if i gradual apply the gas in a smooth manner it won't do this. this even happens on the interstate w/cruise control on and you go up a long grade, it will miss out.
Oct 3, 2007 at 9:58 AM
BUZZSAW
  • 1,198 POSTS
[quote:74f73e786f="magicman53"]toyota tacoma extended cab, 3.4l v-5 engine, 158,000 miles on it. Initially my check engine light came on and it said #1 cylinder misfire so I replaced the 3 ignition wires, changed the plugs. it seem to run better but it bogs down when I mash down on the accelerator. if i gradual apply the gas in a smooth manner it won't do this. this even happens on the interstate w/cruise control on and you go up a long grade, it will miss out.[/quote:74f73e786f]
try coil pack for #1 cylinder
Oct 5, 2007 at 5:52 AM
SERVICE WRITER
  • 9,123 POSTS
"Try a coil pack?" Is that the dealer diagnosing you talk about? :roll:
Oct 10, 2007 at 9:04 AM
Suggested Repair
Try the coil pack for cylinder 1, since the misfire code was for that cylinder and the miss under load continued after the plugs and ignition wires were replaced.
Conversation Summary
The owner of a 1997 Toyota Tacoma with a 3.4L engine and 158,000 miles reported a cylinder 1 misfire code. After replacing three ignition wires and the spark plugs, it ran better but still bogged and missed under hard acceleration or when climbing grades on cruise control. One expert suggested trying the coil pack for cylinder 1; another expert questioned that suggestion and offered no alternative diagnosis.
