1999 Toyota Tacoma Hesitation at 3000 RPM
CMSCHWENKE
[b:3ec8b9d99c]1999 Toyota Tacoma Prerunner 3.4 140000[/b:3ec8b9d99c]
I had my timing belt replaced along with the water pump about a year ago. Since that, I've been having acceleration problems. If I'm on the freeway and I get on the gas, my truck seems to have trouble finding what gear to be in. The rpm stays at a constant 3000ish rpm even if im on full throttle. If I let up on the the trottle a bit, it then begins to accelerate, but not by much. I have no where near the power and accelartion I had before the timing belt change. Last weekend I had the injectors cleaned, replaced differential and transmission fluids, fuel filter changed, new sparkplugs and wires. Ive notice a little more engine response but I am still having the upper 2500 rpm range power loss. Any ideas???
Thanks
Apr 25, 2006 at 9:50 AM
LOSONE
  • 1,616 POSTS
Sound slike you are having tranny problems. I would take it to a dealer and have then reset the computer. If that doesn't help you have tranny problems that has nothing to do with the timing belt replacement. That is a bullet proof engine, the best in may years. Good luck
May 1, 2006 at 5:02 AM
Suggested Repair
Have a dealer reset the engine computer. If the hesitation and failure to downshift under throttle continue, have the transmission diagnosed; the expert says the problem is likely unrelated to the timing belt replacement.
Conversation Summary
The owner of a 1999 Toyota Tacoma reports hesitation and weak acceleration around 2500-3000 rpm after a timing belt and water pump replacement, with the transmission seeming not to select a gear under full throttle. Injector cleaning, fluid changes, a fuel filter, and new plugs and wires brought little improvement. The expert recommends a dealer computer reset and, if that fails, transmission diagnosis unrelated to the timing belt.
