1995 Toyota 4Runner Losing RPMS
140 MILES • 6 CYL • 4WD • MANUAL
BMULLY3100
I live 22 miles from work by the time I get half way
home my RPM's are running 500 or less to where the
engine will stall. This happens when the tempature is
over 95 degrees. All winter it does fine, I live in AZ.
I also can't turn my AC on unless I keep my foot on
the gas when I come to a stop.
Thanks for your help.
Jul 22, 2008 at 6:14 AM
KHLOW2008
  • 41,812 POSTS
Hi bmully3100,
Give the throttle body and IAC a good cleanup with carb cleaner and it should be ok. The idling system is partially clogged thus the low idling speed at warmed up condition.
Aug 16, 2008 at 11:20 PM
