1984 Toyota Pickup Dies at Idle
KEN WILLIAMSON
I have a 84 toyota 4x4 with 22r engine 15000? on new engine all of the sudden when you put the clutch in or try to let it idle it dies. any ideas would be great. thanks
Nov 25, 2007 at 8:11 AM
  • 75,988 POSTS
When was it last tuned-up? check the fuel system could be a choke plate closing/clogged fuel filter/low fuel pressure/idle circuit problem with carb.
An EGR that's crack open/PCV valve or vacuum leak/ignition timing off.
Nov 25, 2007 at 9:14 AM
Suggested Repair
Check when it was last tuned and inspect the fuel system: a closing choke plate, clogged fuel filter, low fuel pressure, or a carburetor idle-circuit problem. Also check for an EGR valve stuck open, a faulty PCV valve, a vacuum leak, and incorrect ignition timing.
Conversation Summary
The owner of a 1984 Toyota Pickup 4x4 with a 22R engine says it dies when the clutch is pressed or when it is allowed to idle, despite a relatively new engine. The expert asks about the last tune-up and recommends checking the carburetor and fuel system, including the choke, fuel filter, fuel pressure, and idle circuit, plus an open EGR valve, PCV valve, vacuum leaks, and ignition timing.
