Fuel stop solenoid, '86, 22R, 4Gear
JFLA_1
  • 1986 TOYOTA PICKUP
Toyota pickup 1986, 141000Miles, 22R, 4cylinder. I recently had the carburater rebuilt, new spark plugs, spark plug lines, rotor and rotor cap. It ran very good for two days and then it would turn off while I was driving. Everytime I don't give it gas the motor will turn off. Toyota diagnosed it ans it said it was a "fuel stop solonoid", my question is if there is another name for this part, because I can not find it, the closest I have gotten to is a "injection pump solenoid" or maybe an "idle stop solenoid."
Thanks.
Monday, August 27th, 2007 AT 12:34 AM
There's no such animal on carbs for 20/22R-find the idle screw should be in between the fast idle screw and the mixture screw. Turn the screw to raise your idle rpm to atleast 750
They probably talking about the dash pot or choke opener diaphragm- Maybe they think your truck is Mazda that uses a fuel cut solenoid
Monday, August 27th, 2007 AT 1:50 AM
