Distributor no spark
1996 TOYOTA PICKUP
LEBARON
i am working on the truck listed above. i have tested the distributor multiple times. i get power to the distributor but no spark out. i have also tested for resistance in the igniter and in the pick up coil. i also changed the condenser in it. i also checked the air gap for the cam sensor and the timing chain is fine too. what do i do?
Feb 22, 2007 at 3:35 PM
KIN CHAN
  • 453 POSTS
You have to look at the wiring diagram and check the signal to the computer. Is the rpm signal return to the ECM that trigger the computer to generate a signal back for ignition? cam sensor defines as signal of rpm input.
Feb 22, 2007 at 8:02 PM
LEBARON
thanks, i would have never thought about the rpm's my next step of course was the ECM since i have been through 3 distributors. thanks again. i was wondering if maybe an anti theft device or maybe a fuel cutoff like some GM's have an anti theft device that will let the car start but will only run for like a second or two does Toyota have anything similar?
Feb 27, 2007 at 3:37 PM
The ECM has to get the G and Ne signals if not it will not give the Igt signal to the igniter and also no igf from the igniter which is a confirmation of an ignition back to the ECM
Also check the injectors whether they clicking/buzzing while cranking.
3 Distributors-start check the wiring to the ECM.
Confirm that the EFI relay,EFI fuse and Ignition fuse are in good shape.
Feb 27, 2007 at 9:22 PM
