1995 Toyota Pickup Runs weak
1995 TOYOTA PICKUP
84,000 MILES • 6 CYL • 4WD • MANUAL
ANJOFRA
I have a 95' toyota 4x4 with the v6. It bogs (feels weak) and hesitates after shifting gears under acceleration but then picks up when it hits a certain rpm and seems ok. It idle's fine, there is no backfire. I changed spark plugs & wires, cap, rotor, fuel & air filters but still no change. Timing is w/in specs. What else can i check? Thank you
Feb 20, 2010 at 12:41 PM
Check and test the airflow meter, throttle position sensor and fuel pressure if all okay-your clutch could be slipping-changing gears and gunning the accelerator and truck won't respond rapidly indicates clutch slipping.
Feb 21, 2010 at 2:50 PM
