1994 Toyota Pickup whirring noise appearing to be coming fr
1994 TOYOTA PICKUP
164,000 MILES • 6 CYL • 4WD • MANUAL
RUSTYBOY
while driving in all gears there is this noise seeming in all gears and is more pronounced when under accelerating/pulling and in decelerating. One can quiet the noise between accelerating and decelerating. You may have answered this type of question, but I could not find one. first thought is wheel bearing, axle bearing or rear end (differential). is there a diagnostic method to pin point the noise w/o tear down?
thanks
Oct 25, 2010 at 2:17 PM
FACTORYJACK
  • 4,159 POSTS
A chassis ear that can be randomly placed throughout the vehicle while it is driven can isolate the noise. If it can be reproduced with the wheels of the ground and run up, you may be able to locate it as well. The fact that it is present on accel and decel suggests possibly a differential type noise, pinion bearing or side bearing. If this is a manual transmission, it could be within that as well. Does the vehicle have a canopy, and sliding windows? Sometimes when it is driven with the window open, the sound can be amplified from the rear and determined. Draining fluids and inspecting may also give an indication.
Oct 25, 2010 at 2:47 PM
RUSTYBOY
Gstacey,
A chassis ear...what is that? Am taking truck to dealer for diagnosis Thurs & wanted to get a handle on possible problems and resoultions.
Oct 25, 2010 at 3:30 PM
RUSTYBOY
[quote:a3a0d187f6="gstacey"]A chassis ear that can be randomly placed throughout the vehicle while it is driven can isolate the noise. If it can be reproduced with the wheels of the ground and run up, you may be able to locate it as well. The fact that it is present on accel and decel suggests possibly a differential type noise, pinion bearing or side bearing. If this is a manual transmission, it could be within that as well. Does the vehicle have a canopy, and sliding windows? Sometimes when it is driven with the window open, the sound can be amplified from the rear and determined. Draining fluids and inspecting may also give an indication.[/quote:a3a0d187f6]
gstacy,
what is a "chassis ear"...presume something like a stethoscope? Will try driving with the rear slider open to see is that enhances to sound. thanks, rustyboy
Oct 26, 2010 at 3:14 AM
FACTORYJACK
  • 4,159 POSTS
Chassis ear is a device made by a company named steelman. It has sensors that can be mounted throughout the vehicle that report to a central switchbox, and through the use of headphones you can switch to each sensor and listen to the noises.
Oct 26, 2010 at 10:47 AM
