1994 Toyota Pickup knock knock
1994 TOYOTA PICKUP
10,000 MILES • 6 CYL • 4WD • MANUAL
RANDOM_HERO
I was drive earlier today and all of the sudden my engine started making a knocking noise at about 2500 Rpm's. Then it started to get worse and it sounded like it was only one cylinder and it was coming from the top portion of the block. I was wondering if it was a valve the was hitting the piston. I just put in a rebuild engine in January of 2008 so i hope its not a huge deal.
Jul 21, 2008 at 4:14 PM
DOCFIXIT
  • 18,828 POSTS
AT idle rev engine does sound go along with the RPMS? Then take it up quick to 2000rpms let off quickly What happened?
Let me know
Jul 21, 2008 at 4:24 PM
RANDOM_HERO
yes it does go along with the RPM's. As the RPM goes up the knocking speeds up as well.
Jul 21, 2008 at 4:34 PM
DOCFIXIT
  • 18,828 POSTS
Knocking like someone is in the engine with a hammer? If so rod bearing failure .
Jul 21, 2008 at 4:38 PM
RANDOM_HERO
ya it does somewhat sound like that and it takes a second to start up too.
Jul 21, 2008 at 4:45 PM
