1991 Toyota Pickup wont start
PRIMOJR
  • 1991 TOYOTA PICKUP
  • 6 CYL
  • 4WD
  • MANUAL
  • 296,000 MILES
Theres power even when it cranks. No spark already changed ignitor coil and ignition control module. Whats next?
Sunday, October 12th, 2008 AT 3:19 PM
KHLOW2008
  • 41,814 POSTS
Hi primojr,
Thank you for the donation.
You mean power is available at distributor even while cranking and you are not getting sparks? This doesn't seem logical unless the rotors are not turning which might mean a faulty timing belt.
With distributor cap remove, crank the engine and see if the distributor rotor is turning.
Sunday, October 12th, 2008 AT 4:23 PM
