Engine no start
USICKID
  • 1988 TOYOTA PICKUP
  • 6 CYL
  • 4WD
  • MANUAL
  • 230,000 MILES
I was driving down a slight hill when my engine shut off. I tried restarting it but it wouldn't restart. I had about a quarter tank of gas and it was siting out in the cold for a couple of days prior to driving it if that makes a difference. It usually starts fine in the cold weather with help from an engine block heater. Ive tried starting the truck later with the aid of starting fluid but no luck. The truck cranks but does not turn over I just hope its not dead :(
Thursday, January 15th, 2009 AT 2:54 PM
ISLAND_PRIDE71
  • 62 POSTS
Have you checked for spark? If you haven't, disconnect a sparkplug wire and ground it to the engine and get a helper to crank the engine over. Are you getting a blue spark? If not check the ignition fuse, check for power at the coil-got power to coil test the coil, distributor pick-up coil and the ignitor
Thursday, January 15th, 2009 AT 5:41 PM
USICKID
Ok so I removed the top screws off the timing belt cover which was just enough to peek inside and found that the belt had broke. Has anyone have any experience replacing the timing belt? Ive also read that my pistons and valves should not have been damaged is this true? I'm thinking of taking it in to a shop and just wanted to get a few opinions on it thanks.
Sunday, January 18th, 2009 AT 2:21 PM
ISLAND_PRIDE71
  • 62 POSTS
Is this a 3MZ-FE engine?-If so its an interference engine
Sunday, January 18th, 2009 AT 2:48 PM
USICKID
No it a 3vz-e 3.0 V6 engine which I confirmed is a non-interference engine. Thanks
Sunday, January 18th, 2009 AT 4:32 PM
ISLAND_PRIDE71
  • 62 POSTS
3vz-e 3.0 V6 engine your confirmation is correct
Monday, January 19th, 2009 AT 6:20 PM
