I have a 1987 Toyota pickup that wont star. I replaced the battery the cables and it started up just fine ran about 2 weeks then started the same problem all over again battery shows 13.1 volts on the voltmeter I used alternator shows 13.3 volts when running. Now all I get is a click at the starter relay was doing this before I replaced parts when I turn key on everything lights up but wont start will push start
SPONSORED LINKS
Tuesday, August 3rd, 2010 AT 6:42 PM
