1986 Toyota Pickup engine stalls
TOY--TROUBLE
  • 1986 TOYOTA PICKUP
  • 4 CYL
  • 4WD
  • 111,600 MILES
My engine idles rough after it warms up then it will stall when I come to a stop, tried increasing idle screw can smell it running rich at Idle. Changed mass air flow changed catalytic converter changed o2 sensor has low power untill the rpm are higher?
Monday, December 3rd, 2007 AT 7:47 PM
Check the idle air control valve, throttle position sensor and EGR system.
Monday, December 3rd, 2007 AT 7:54 PM
DEARHUNT05
Just a thought have you check out the oil pressure switch?
Saturday, March 15th, 2008 AT 10:52 AM
