2003 Toyota Solara Dies While Driving
TOYOTA
AURORA2B
Ok, So like the great gal that I am I dont do the whole maintanance thing on my car....I think this time I really screwed up. My car is a 2003 Toyota Solara V6 with 72K milies or so. its is an automatic.
I started the car and went down the street....then it died. the check engine and oil light and battery light came on, but the radio stil worked, I had a full tank and no sputtering happenned and there had been no noises or signs of any car problems . so I waited and started it again it started and then died a couple miles later.
When I got home I checked the fuilds and the oil is a bit low, there was no coolant. and there was some corrosion on the battery.
Do I need to take it in to the mechanic or is it possible that I just need to fill the fluids.......
help
May 13, 2007 at 8:36 AM
  • 75,988 POSTS
[quote:ed9194b351="aurora2b"]Ok, So like the great gal that I am I dont do the whole maintanance thing on my car....I think this time I really screwed up. My car is a 2003 Toyota Solara V6 with 72K milies or so. its is an automatic.
help[/quote:ed9194b351]
Fill the fluids and take it in and have them check the fuel pressure to identify a failing fuel pump for a start
Your problem could also be in the ignition system
HTH Good Luck
May 13, 2007 at 12:41 PM
CYRIL PINAS
Torque seguence of cilinderheadbolts
Torque specifications of:
cilinderheadbolts;
connectingrodnuts;
mainbearingbolts;
damperpulleybolt and
flywheel/flexplatebolts.
Thanks so far.
Aug 13, 2007 at 9:27 PM
  • 75,988 POSTS
[quote="cyril pinas"]Torque seguence of cilinderheadbolts: work from center out
cilinderheadbolts; 84-97lbs
connectingrodnuts;35-54lbs
mainbearingbolts; no.1-3 91-108lbs no.4 76-94lbs
damperpulleybolt : 116-144lbs
flywheel/flexplatebolts:58-79
Hope this helps you-Good Luck
Aug 13, 2007 at 9:51 PM
Suggested Repair
Fill the oil and coolant, then have a shop check fuel pressure for a failing fuel pump. The ignition system is another possible cause.
Conversation Summary
A 2003 Toyota Solara V6 died while driving with the check engine, oil, and battery lights on, then restarted and died again. Oil was slightly low, coolant was empty, and the battery had corrosion. The expert advised filling the fluids and checking fuel pressure for a failing fuel pump, and also noted a possible ignition-system problem. A later reply requested unrelated engine bolt torque specifications.
