1981 Toyota Corolla Starts Then Dies
RICHARDD
Hi, I have a 1981 ke70 corolla with the 4kc 1300cc motor. It has done 200,000km. I was driving today and the engine died. It was just like turning off the key. Every time I try to start it the engine fires and then immediatly dies. It will start but will not run even for a second. fuel is ok do ypu have any other ideas?? Thanks.
P.S. this is the Australian corolla if that makes any difference.
May 5, 2007 at 9:26 PM
  • 75,988 POSTS
Check your coil and distributor pick-up inside and its connections if its okay check the ignition switch in and out
May 6, 2007 at 7:57 AM
RICHARDD
problem was coil resistor. fixed it yesterday thanks.
May 7, 2007 at 10:03 AM
Suggested Repair
The confirmed fault was the coil resistor, which was replaced. If the same symptom returns, check the ignition coil, the distributor pickup and its connections, and the ignition switch.
Conversation Summary
A 1981 Toyota Corolla with the 4KC engine died while driving as if the key had been turned off. It would fire but stall immediately and would not run even briefly, though fuel was present. The expert suggested checking the coil, distributor pickup and connections, then the ignition switch. The owner later reported that a failed coil resistor was the cause and that replacing it fixed the problem.
