1989 Toyota Corolla No Start
Suggested Repair
Do not use starting fluid. Confirm the fuel pump runs for about five seconds with the key on and the engine not cranking. Use a NOID light, not a test light, to see if the injectors are pulsing; that computer signal also requires a cam sensor input. Follow the no-start guide and report the results.
Conversation Summary
A repaired 1989 Toyota Corolla with a twin-cam engine cranks but will not start. Spark was restored after a coil replacement, fuel reaches the rail, and starting fluid in the throttle body runs it briefly. A test light shows voltage at the injectors. The expert says the injectors may not be pulsing, a NOID light is needed to check the computer pulse and cam sensor input, and the fuel pump prime should be verified. Starting fluid should not be used.
