1989 Toyota Corolla intermittent starting problems
NINJAFERRET
  • 1989 TOYOTA COROLLA
  • 6 CYL
  • MANUAL
  • 197,000 MILES
Hi and thanks in advance for the advice!
My 1989 Toyota Corolla GT-S (manual transmission) has an intermittent problem with starting: when I turn the key in the ignition, there is no click, no laboring of starter, just a low sound like a fan coming on somewhere in the engine. The lights and radio work. If I push-start or roll-start the car, it starts, then for the rest of the day, it starts up fine, but if it sits overnight it will not start in the morning.
The starter was replaced 400 miles ago: the problem has been intermittent since then, but at first it only happened once a month- now it happens every time I park it over night.
Is it the starter, the batter, the alternator? Help!
Thanks!
-Laura
Wednesday, April 7th, 2010 AT 6:49 PM
2CARPRO JACK
  • 11,533 POSTS
Sure sounds like a bad starter solenoid. If the solenoid goes bad, the motor will still turn the gear, but without the solenoid it wont engage in the flywheel and turn the engine.
Wednesday, April 7th, 2010 AT 9:56 PM
NINJAFERRET
Thanks so much for letting me know the problem! This is great!
Wednesday, April 7th, 2010 AT 11:19 PM
2CARPRO JACK
  • 11,533 POSTS
You are welcome and thanks for using 2CarPros. Com
Thursday, April 8th, 2010 AT 7:26 AM
