to get it started i have to add carb cleaner directly to the carburator.
what is the problem, i bought a new fuel filter, and it ran fine for a day or so. but i just got stuck today.
it ran fine once it got started.
Check whether the automatic choke is binding and closing the choke plate when the engine is hot, which can cause a hot no-start. Also inspect the carburetor for flooding, a loose or broken hold-down bolt, water contamination, and a collapsed preheat hose.
A 1987 Toyota Corolla FX starts and runs when cold, but after sitting hot for 30 minutes to an hour it cranks without starting. Adding carburetor cleaner helps it start, and a new fuel filter only helped briefly. The owner later reported water in the carburetor, a delaminated and clogged carburetor preheat hose, and flooding caused by a broken carburetor hold-down bolt. After addressing those issues, the car started reliably, though sometimes slowly. An expert suggested the automatic choke may be binding and closing the choke plate when hot.
