1992 Toyota Corolla Won't Start
WHEATAMANDA
  • 5 POSTS
my car wont start, i have replaced the battery, radiater, fuel filter, tune up, and it wont start. it wants to start and you can hear the gas flowwing, any ideas?
Mar 4, 2007 at 4:00 AM
  • 75,988 POSTS
[quote:cceac9207c="wheatamanda"]my car wont start, i have replaced the battery, radiater, fuel filter, tune up, and it wont start. it wants to start and you can hear the gas flowwing, any ideas?[/quote:cceac9207c]
Do an ignition system check-look for spark while cranking, at the sparkplug wire while grounded.
Mar 4, 2007 at 12:56 PM
WHEATAMANDA
  • 5 POSTS
does that mean to check the plug because i have done that, someone said the wires could be on backwards, how do you know?
Mar 4, 2007 at 11:56 PM
  • 75,988 POSTS
Put the engine's no.1 cyl on TDC and follow the firing order-you need a book
Disconnect the coil wire, while cranking the engine over look for spark while grounding the wire.
Mar 5, 2007 at 6:03 AM
Suggested Repair
Check for spark while cranking by grounding a spark plug wire, and also disconnect the coil wire and check for spark while grounding it. Confirm the plug wires are not reversed by setting cylinder 1 to TDC and following the firing order in a service manual.
Conversation Summary
A 1992 Toyota Corolla cranks and fuel can be heard flowing, but it will not start after the battery, radiator, fuel filter, and a tune-up were replaced. The expert advised checking for spark at a grounded spark plug wire and at the grounded coil wire while cranking, and verifying the firing order with cylinder 1 at TDC using a manual.
