1992 Toyota Corolla Cranks No Start
ED51
  • 16 POSTS
1.6L, 16-valve DOHC, 4-AF engine, 198,000 miles. Car died on freeway and will not start; engine cranks good, no check engine light codes. Towed to home and checked for fuel, compression and spark present. Fuel and compression were within specs except spark was doubtful. Checked spark with a spare plug and it was thin and yellow on all except No.1 which is wide and white. Coil Pri and Sec resistance and air gap were checked OK. There is 12V to the coil. There’s power to all fuse boxes and all fuses and relays are good. Distributor cap and spark plug wires are new. Autozone could not test the Igniter (no manual available) or by a repair shop. I think I got it narrowed down to a weak spark problem but I'm not sure if it is the Ignition Control Module. Is there another way to test the igniter without using a tester? Anybody with this type of problem? I appreciate your suggestions.
May 29, 2007 at 3:14 PM
  • 75,988 POSTS
Check the high tension coil wire
Do a primary and secondary windings check on the coil
Check the the pick-up gap in the distributor and its resistances at G1-G- 185-265 ohms Ne-G- 185-265ohms
Coil and pick-up checks out-its in between the ignitor and the computer
Note: If computer don't see Ne and G signals it will not sent an Igt signal to the ignitor telling it to fire the coil and also it kills the injection system.
May 29, 2007 at 4:01 PM
Suggested Repair
Check the high-tension coil wire, coil primary and secondary windings, and the distributor pickup gap and resistance (G1-G and Ne-G should each be 185-265 ohms). If the coil and pickup check out, the fault is between the ignitor and the computer: missing Ne and G signals prevent the IGt signal that fires the coil and also shut off fuel injection.
Conversation Summary
A 1992 Toyota Corolla with a 1.6L 4-AF engine died on the freeway and cranks but will not start. Fuel and compression were within specs, fuses and relays were good, and the distributor cap and plug wires were new, but spark looked weak and yellow on most cylinders. The owner suspected the ignition control module. The expert advised checking the coil wire, coil windings, and distributor pickup gap and resistance, then the path between the ignitor and computer if those pass, because missing Ne and G signals stop both spark and injection.
