Check fuel pressure and spark, also there is an inspection cover in the timing belt cover, take it off to see if the belt is broke or missing teeth.
Fuel pressure is checked by removing the cold start valve from the fuel rail and screwing in a special fitting with a shraeder valve on one end. This may be hard to find, so it may need to be done by Toyota.
I would check the timing belt and spark first.
SPONSORED LINKS
Friday, June 20th, 2008 AT 6:52 AM
